Display the VTEP Next Hop
Use the following procedure to display information about the remote VTEP.
- Select VTEP.
- Select the Next Hop tab.
Next Hop Field Descriptions
Use the data in the following table to use the Next Hop tab.
| Name | Description |
| VtepId | Specifies an index value in the range from 1 to 500 that uniquely identifies this remote VTEP. |
| Ip | Specifies an IP address that uniquely identifies this remote VTEP tunnel. |
| IfIndex | Specifies the interface index of the next hop to reach the remote VTEP. |
| Vid | Specifies the VLAN ID of the next hop to reach remote VTEP. |
